998 turbo mod
Turboflash
Southern MN
'17 ZR9000 Ltd. 137 - PEFI Stage 4
Recently, I completed a turbo modification that consisted of changing out both compressor and turbine wheels with the goal of improving air flow/efficiency in a stock system.
My attitude going in to this project was this is an experiment on an occasional use toy. If it works, then great and I'll be pleased. If it doesn't, then I'll change it back to stock.
My qualification on whether or not it was successful was to evaluate pre and post track dyno HP. If dyno HP was higher after change (with no other changes) then turbo must be performing better. If not, then change was not beneficial.
Summary:
1. There is a gain. Stock wheels are not optimal.
2. Without divulging the exact details, the engine performs better with mod turbo.
3. Without divulging the exact HP numbers; let me just say I had to increase fuel pressure about 5-6 lbs to keep same AFR as before change (in cooler 53 degF air). Keep in mind, the air temp and humidity was much cooler and dryer on test before change. So, having to increase fuel pressure that much with much warmer and humid air in dyno after change only means there was more air going through engine which equals more HP. The engine is an air pump. More air volume = more HP (everything else being equal). (P.S. I know the track HP change).
The cost of change, to me, was conservative. Less than $1000.
Was it worth it? Depends on your perspective and expectations.
I
Are you keeping the details secret because you plan on selling it as a kit at a later date?
Absolutely not.
Summary:
I
So...I'm assuming it was a simple increase in fuel pressure for the dyno, but what are the thoughts on the existing tunes dealing with the better efficiency for trail use? New tunes?
There's more air so if the tune can't adjust for that, it will be lean. Not innocently so. I think it will be enough to be trouble.
I think it will push the closed-loop tunes to handle it too. I don't have any experience with closed-loop as far as how much they can adjust. Without any way to increase fuel flow on normal tunes (non-closed loop) I would say it will be trouble.
The closed loop tune will try to adjust AFR based on what it is being told by the O2 sensor. This means maxing out the operating window of the injectors (max duty cycle). If there is not enough fuel pressure available or the injectors are too small, the system will run lean while the closed loop constantly tries to compensate but will never hit target AFR. Raising the fuel pressure should address the lean condition.
Yes, but for those who don't have closed loop, and don't have AFR data, and think/hope their current tune would be ok with this mod, I doubt it.
As you mention, I don't know much closed loop can compensate. Once injectors are maxed out and/or there's not enough fuel pressure available, closed loop can't help.
Without doing the math, I don't know how much more fuel is delivered with a 5-7 lb increase in fuel pressure. Also, keep in mind the Stage 4 PEFI tune is a 4-bar tune to begin with. Meaning base fuel pressure is 58 lbs.
I have closed loop and with stock fuel pressure it maxes out at just under +25% compensation on the data log to try to meet the tunes AFR demands
I have had to raise my SW stock injector fuel pressure to @ 50 psi ,from the sock 42 psi, with my header tuned SW on the 300hp setting to keep AFRs safe.
Do the injectors get changed out with PEFI stage 4?
No. The "kit" comes with a fixed 4-bar regulator (58 lb) and a 4-bar MAP sensor.
Based on my track dyno results, likely I might need to run about 63-64 psi static.
BTW- at 18 psi boost, that's about 82 psi fuel pressure. My understanding is:
a) my TD adjustable fpr can handle 100 psi
b) the stock injectors are ok up to about 85-90 psi. After that, larger injectors would be required.
Does make me wonder how close to the edge I am with waste gate lock in, 25 psi boost, w 63-64 psi static = 88-89 psi on injectors?
So far so good. AFR was steady at low 12's on dyno; C16 fuel. No indication of fuel starvation. Good thing for C16, lol.
Post-dyno fiber optic camera inspection showed piston crowns happy and plugs looked good too.
Still can't run wfo for miles, lol.
TF, please refresh me..what's the difference between the 3bar & 4bar Map?
Or maybe a better question is, at what boost level is a 4bar needed?
Note: earthling gave me a great explanation on this matter, can't find.
It looks like the 3 bar map is good till 17psi and the 4 bar 25psi. If true I'll need to switch to a 4 bar.
It depends on what the tune was "written" with. 3-bar tunes use base 43 psi fuel pressure. Injector pulse width is calibrated to that to meter the correct amount of fuel.
4-bar tunes use 58 psi as base. Again, injector pulse is controlled by ecu to that base pressure. It is not determined by how much boost there will be, directly.
You can't just change a 3-bar tune to 4-bar, or vice versa, on same tune map. Fuel control will be way off. I doubt the engine would start, and even it did, it wouldn't run well at all.
Theoretically, within a range, you can get to the same place with 3-bar or 4-bar with same injector. With 3 bar, the injector pulse width ("on" time) will be longer because fp is lower. With 4-bar, pulse width will be shorter because fp is higher.
PEFI decided to create their Stage 4 tune as a 4-bar, I assume to ensure adequate fuel flow, and not push injectors to maximum duty cycle (amount of on time compared to off time). If an injector is undersized, it will have to on too much and that will overheat it and cause failure.
I was under the impression that each Map sensor had the ability to read a certain amount of manifold pressure, and that's it.
So once the threshold was reached, it's time to upgrade the map.
As for the stock fuel injectors, im pretty sure they are being over taxed in or around 350hp +/-
Sure they'll fire, but I understand when running at 100psi or 110% duty cycle for any great length of time, failure is eminent at some point.
Like you stated, I believe Hurricane, TD and PFI use a little bit of a different method to reach the same goal.
