scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
Hey guys, hope someone can help me understand this. I have the Bikeman Performance BOV on my sled. Last winter I was running the evo Stage 0 tune (fuel correction for aftermarket exhaust - NO HP increase) and when you hit the throttle real hard and then let off immediately you could hear the BOV releasing pressure (pretty loudly). Now, fast forward to this winter I changed the tune to stage 4 (58 HP over stock) and now I do the same thing and I don't hear the BOV at all.... Nothing. Is that normal? Is that just the change in HP/PSI (stage 4 is 14.5psi boost). Just want to make sure I don't have a problem!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I would think your good if it runs good. Ride it!
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
You should hear the bov, take it of and set pressure on it to see when its opening. I think its open at 14,5 psi and maybe you have to have a stiffer bov springHey guys, hope someone can help me understand this. I have the Bikeman Performance BOV on my sled. Last winter I was running the evo Stage 0 tune (fuel correction for aftermarket exhaust - NO HP increase) and when you hit the throttle real hard and then let off immediately you could hear the BOV releasing pressure (pretty loudly). Now, fast forward to this winter I changed the tune to stage 4 (58 HP over stock) and now I do the same thing and I don't hear the BOV at all.... Nothing. Is that normal? Is that just the change in HP/PSI (stage 4 is 14.5psi boost). Just want to make sure I don't have a problem!
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
I’m running evo stage 4 and I sure can hear my BOV.
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
What BOV are you running? Stock or something else?
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
What BOV are you running? Stock or something else?[/QUOT
TurbosmartWhat BOV are you running? Stock or something else?
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
I haven't pressure tested it yet (need to get another fitting tomorrow) but I pressed in the BOV with my thumb (both the stock BOV and the Bikeman) and actually the stock one is harder to press in than the bikeman.... I'm stumped as to why this has changed since the new tune. Doesn't make sense to me
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
Do you also have a CAI?
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Yes.....Do you also have a CAI?
Turboflash
- Mar 18, 2019
- Southern MN
Just thinking out loud, I wonder if the solenoid failed?
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
What solenoid? Where is it? Thanks
Turboflash
- Mar 18, 2019
- Southern MN
Trace hose that's plugged onto it. Hose goes up to one of the solenoids just below the main fuse block at the front of the engine compartment.What solenoid? Where is it? Thanks
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
Do you know if it would be part 34 or 35? Also do you know the purpose or what the solenoid does that may affect the opening of the BOV? I appreciate the help
https://www.babbittsonline.com/oemparts/a/yam/59b6bce887a86611549410a6/intake
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
does anyone know the purpose of those two solenoids?
Turboflash
- Mar 18, 2019
- Southern MN
One runs BOV and the other runs the waste gate.
- 18K
