mewassin
- Jul 8, 2011
How do you remove the a-arm boot retainers with the triangle shaped recess in the head?
tapp1
I believe the boot should slip over the "pin". Just pull the rubber around them.
Mazz
Are you talking about the rivets, one on each side? If so I just drill them out and replace with an automotive plastic push pin. They have held up great and are easily removable.
Mazz said:Are you talking about the rivets, one on each side? If so I just drill them out and replace with an automotive plastic push pin. They have held up great and are easily removable.
X2
I went to the hardware store and picked them up for about $1
![](/styles/vip.gif)
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
You can actually work the rubber out from under the rivets then stretch the boot back over the rivet head to reinstall. No need to remove the rivets.
