viperwings
- Oct 28, 2007
- Michigan
- Attack GT & Nytro XTX
- SE Michigan
I have a 2012 Nytro XTX and I need to get some help with the Clutches and engine alignment. Is there anyone who can help me? I am in the Milford, Brighton, Novi, White Lake area and would like to find someone local that could give me a hand with this. Please let me know if anyone is knowledgeable in this area to reach out to. The problem is that I keep blowing belts. I have gone through and checked all the common areas of concern but still not sure that the engine is square, and the clutches are aligned. Thank you, Terry
Call Thunder Products Clutching. @Thunder Products
thunderproductsclutching.com
Home - Thunder Products Clutching
Peak Shifting Performance "The Original" Thunder Shift Kit, Heavy Hitters, and more! Welcome to Thunder Products Clutching. We are your NEW source for snowmobile and ATV clutch performance upgrades. Here you will find tried and true clutching upgrades proven to give you spot-on holeshots...
