RX1Jim
Freddie,
The 1000 cc 4 cylinder engine used in the 2006 sleds is reported to have 150 hp. The engine used in the R1 sportbike (4 cylinder, 1000 CC, 5 valves per cylinder, FI) is reported in several cycle magazines as making 175 hp. Other than the abscence of the reduction gear on the output of the sled engine, what do you think is different about these 2 engines? The R1 bike engine is super reliable, so we should be able to develop that level of power in the Apex/ Attack engine. Cams, timing, compression, higher flow head?? Thanks!
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
Ram Air maybe?
Black 1000
Just my $.02 but I think it's cams timing and porting.
LazyBastard
You can't make it into an R1. They have different pistons and cams, as well as a slew of other parts, AND, the R1 engine spins faster (12500 rpm).
mmmkokanee
02 and 03 R1 only had 150 hp efi, 04 and newer bikes are diff bore, stroke, etc
SUPERTUNER
- Aug 16, 2003
- Waterbury, Connecticut
- www.easterncycleperf.com
RX1Jim said:Freddie,
The R1 motorycles have the ram air which is worth about 4 HP at 120 MPH. They also have different camshafts, camshaft timing and compression ratios are higher.
It has been my experience that whatever motorcycle or snowmobiles magazines claim for HP, deduct 10% to 12% and you will be pretty close.
The wider range of aftermarket exhaust systems and the fact that they have Dynojet Power Commanders available for the fuel injected models of motorcycles allow us to tune the motorycles to a much higher degree.
Freddie
- 8K
- 6K
