wacnstac
Check out where my skis are attached in this picture. Would I be able to move them to the outside one notch for a bit wider stance? Any downside?
Sent from my HTC6500LVW using Tapatalk
MikeWalters
Yes move to outside for stability. I did with no ill effects, however I don't put on a lot of miles in a season.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
It's a standard mod on most Yamaha sleds. Haven't heard of or seen any ill effects except on the trailer if width is limited.
wacnstac
Is this mod described on this site anywhere?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
No but it's very easy. Remove bolt, move spacer to the inside, re-install bolt.
goby
- Jan 30, 2008
- Umeå
- Sweden
- 18 Titan Adventure 800
17 SideWinder BTX 153 LE
16 SR Viper MTX 153
16 SR Viper MTX 153
91 GLX Finlandia LTS
87 Skandic 377R
86 Skandic 377R
83 ET 340
Add weight to the skis, lift the skid in the front
I'm using a Phazer MTX narrow front end together with FOX shocks, have also used the stock front end together with FOX and the skis at max stance.
Not a big difference compared to the narrow setup. Sway bar removed (not possible with weak front end shocks/springs)
The MP is really unstable when the skid is carrying too much weight in the front instead of the front suspension
/G
/G
campsleder
Also do the nitro mod of 2mm off the upper A arm knuckle works great !
