aaen pipe install
dremmick
Savage, MN
2008 Nytro
I bought a used aaen pipe at hay days and need some help installing it. Aaen instructions are horrible there are no pictures. Does anyone know where that darn t brack mounts to?
Interested in this as well, I bought a used aaen system over the summer and still want to install before the season.
If it looks anything like the pic on their website it looks like it bolts into the stock bracket locations. I don't have that header but I've been wanting to buy the aaen header for a while now and haven't pulled the trigger. Could you post a picture of your header and hardware and maybe someone could point you in the right direction?
I bought the whole system from AAEN last year at haydays and ran into the same issue trying to figure it out . I fou d one picture online that showed it and I believe it was on TY if I recall? On a blacked out mtx if I recall. I'm at work for another week , otherwise I would get a pic for ya. If I remember right you use the stock rubber mounts on the rear and put the two bolts in with the single piece of the tee upward and the plastics attach to it? It was last year I installed so don't quite rember. Hope this helps.
thanks! I hear They are LOUD! hopefully not to loud where its annoying
Look up Yamasquaw on you tube . That's my channel. You can hear it abit on there.
I have a brand new pipe with all of the mounting hardware and instructions at home. I'll be away until the end of the week but I should be able to post a picture or pdf for you. Also, I am selling my brand new pipe if anyone is interested. Decided to keep it stock.
