I'm trying to adjust the reverse linkage but just cant even get in with my hands or tools to adjust them. What is the best course of action? Does the brake caliper have to be removed?
I THINK your chassis is the same as my 05 Vector (RS90RK). If this is true, you can remove the cooling system hose that runs vertical in the same area of the linkage. Remove it from the overflow bottle. You will lose very little coolant.
I have a 2012, when it needed adjusting the mechanic took the caliper off...the bolt holding the linkage to the engine came loose and I had to do it again and didn't take the caliper off but it wasn't easy to get to
