Adding STM Tunnel Protectors
snowdust
Northern Illinois
Sidewinder
Anybody added the STM protectors after adding the factory protectors in the rear? I assume they will still slide into the channel fine but wanted to check. Also - Are the rear tall enough to run 1.65's or would I need to add the STM rears as well? I see they make some that go on in addition to the factory added rears but that may be for really long studs.
Yes you can install the fronts still.
