jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
I’m looking at going with a stock exhaust tune. Has anyone tried adding weight to the stock weights vs going with aftermarket? Can you buy heavier rivets for the sidewinder clutch weights?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
They already have the 4.5gr in each hole for 17-18. Never found heavier rivet
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Get the thunder heavy hitters
bleedyamaha
- Sep 28, 2013
- Northern Iowa
So what do the stock weights weigh ?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
59gr EMPTYSo what do the stock weights weigh ?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I had a tune with stock weights with a package that I bought through my dealer. He removed the tip weight and just simply added a washer to the new (same) rivet weight which added about 1.25 grams.
When Bender was was doing Yamahas years ago he used to sell lead rivet weights for the SRX.
Not sure if anyone is doing that anymore.
Depends on the tune. Ben at TD says stock weights are OK with ecotrail tune with SM.I’m looking at going with a stock exhaust tune. Has anyone tried adding weight to the stock weights vs going with aftermarket? Can you buy heavier rivets for the sidewinder clutch weights?
Yamaha used to offer lead rivets, but I don't think they do anymore.I had a tune with stock weights with a package that I bought through my dealer. He removed the tip weight and just simply added a washer to the new (same) rivet weight which added about 1.25 grams.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
The aftermarket weights must have a more aggressive curve maybe to achieve more force with the same amount of weight?
actionjack
- Apr 9, 2005
Yes I believe this has been mentioned. I ran my TD clutch kit with too-heavy Dalton weights (74.7g) for a day on stock tune and I couldn't pull peak rpms but it was perfectly driveable and still more than the 3 Apexes with me could keep up with. If you're going to be changing weights anyway I would consider getting Dalton 70g weights (QAY-70), start empty and add from there. Easier to adjust than stock and you can get them to almost 78g if you need more weight when you tune her up.The aftermarket weights must have a more aggressive curve maybe to achieve more force with the same amount of weight?
Agree. TD sent me DTYA-1's, but QAY-70's would have been better.Yes I believe this has been mentioned. I ran my TD clutch kit with too-heavy Dalton weights (74.7g) for a day on stock tune and I couldn't pull peak rpms but it was perfectly driveable and still more than the 3 Apexes with me could keep up with. If you're going to be changing weights anyway I would consider getting Dalton 70g weights (QAY-70), start empty and add from there. Easier to adjust than stock and you can get them to almost 78g if you need more weight when you tune her up.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Daltons have a more aggressive curve to "act" heavier then very flat YAM weights. Daltons work much better accelerating vs stock weights(at same rpms).
For the price of them, Its something well worth it IMO. Rather then adding weight to a stock weight tip, and still having a slower accelerating weight in the end. Not to mention how backshift gets slower/worse when adding weight to stockers.
Dan
Dan
kimcoop1324
- Oct 7, 2013
- New Hampshire
- New Hampshire
Hey Dan when adding weight to Dalton arms go you recommend turning weight to full stop or 1/4 turn to full stop. Thanks mikeDaltons have a more aggressive curve to "act" heavier then very flat YAM weights. Daltons work much better accelerating vs stock weights(at same rpms).
Dan
saskattakman
I have some heavier brass weights if anybody needs shoot me a pm
