Derek Turnbull
- Apr 7, 2017
- Maine
- 2018 Yamaha Sidewinder LTX-LE
Racing Blue
Do you think they will make any clutching changes for 18?
Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
anyone try a spring such as a Hauck orange in the primary or a Yamaha GWG and stock weights? Hauck is 55 preload...same as stock spring but higher overall force @ 136.
just thinking most stock set ups are running low rpms, this should raise it...hopefully not too much?
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
My take....From my past experiences with the Hauck Orange spring in the primary: don't do it. It was designed as a racing spring and has short life span similar to that of a mentally challenged may fly. If you want to play with different primary springs I would stick with either OEM or quality aftermarket like Dalton or EPI.
If you need to raise your top rpms the best way to accomplish this is to lighten up your fly weights instead of changing your spring IMHO.
WTF...It's only Aug. 1 and we're already talking clutching?
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I think all the 18's will be coming with brand new clutches.Do you think they will make any clutching changes for 18?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
bold statement considering this is YAMAHA we are talking about....."what problem"I think all the 18's will be coming with brand new clutches.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
The clutches are the same. No changes for 18 unless there is small adjustments to the same clutch.I think all the 18's will be coming with brand new clutches.
XP123
- Dec 25, 2016
- Chautauqua NY
This may be true but that doesn't change the fact that all the 18's will be coming with brand new clutches.The clutches are the same. No changes for 18 unless there is small adjustments to the same clutch.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Well if that is the way you want to put it, the 18's will have everything new. From the snow flap all the way to the tip of the skis!
Reminds me of a saying, "Hard telling not knowing"
Dam hot out today huh??
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
2018s come with all new Yamaha engines and turbos , tracks , and even skis , not old used ones.This may be true but that doesn't change the fact that all the 18's will be coming with brand new clutches.
Derek Turnbull
- Apr 7, 2017
- Maine
Racing Blue
Good Stuff!! But seriously. It seems like they had some serious issues with springs binding on the primary and secondary side causing some issues!! I hope for my sake they get them figured out for 18 or should I plans on a full clutch kit not just weights?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I defiantly have one of the sleds with both clutches showing spring bind and belt blowing is a major issueGood Stuff!! But seriously. It seems like they had some serious issues with springs binding on the primary and secondary side causing some issues!! I hope for my sake they get them figured out for 18 or should I plans on a full clutch kit not just weights?
I have a lot of ideas to try but I don't feel like I have a fix yet.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Pick up a complete kit thunderproducts is good from stock to max boost on pump fuel and infinitely adjustable then your ready for when you crank it up! LolGood Stuff!! But seriously. It seems like they had some serious issues with springs binding on the primary and secondary side causing some issues!! I hope for my sake they get them figured out for 18 or should I plans on a full clutch kit not just weights?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Are you talking about the big venom kits for sidewinders. I believe these come with glide washers I think.Pick up a complete kit thunderproducts is good from stock to max boost on pump fuel and infinitely adjustable then your ready for when you crank it up! Lol
This is the kit top on my list so far.
Derek Turnbull
- Apr 7, 2017
- Maine
Racing Blue
I will be cranking up right from the get go looks like hurricane 270hp kit... which comes with weights and freeflow muffler
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I'm going to send my clutches out to be balanced. I will install the rest of Thunder Products Big Venom kit. I already have primary spring, 911 cover & glide washers. Then i will set offset to 60 to 61mm. From there just adjust rpm's to stock motor specs........for now....
- 15K
