rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Someone chime in having stock weights for ms16..can I use stock weights?
Try it., make sure the end rivet is heavy and use the xs 825.Someone chime in having stock weights for ms16..can I use stock weights?
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
MS16Someone chime in having stock weights for ms16..can I use stock weights?
8jp, 35° helix, stock primary, Dalton's @ 72g, Dalton Blk/Org = 8950 (for me)
How much do the stock arms weigh?
Can't directly compare weight as they don't have the same profile.MS16
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
The profile literally changes EVERYTHING.
@rtx moose I ran modified stock weights in my sled with the stock muffler bundle(up to 160hp) until they wore out at 12000kms.
I had added a few grams to them, but my revs were usually 87-8800ish
Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
Nope over rev unless you add weight been there done that!
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Yes you can. I have for 4,000 miles with an XS825 belt.Someone chime in having stock weights for ms16..can I use stock weights?
I can’t predict what it will rev with the 8JP.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
What is the process? Remove the weights, drill out the stock rivets, and install heavier rivets with a rivet gun?FYI, Hauck powersports offers a 5.9 gram rivet if you want to add more weight.
As I understand it, the heaviest Yamaha rivet is 4.5g.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Install heavier rivet by holding it sideways on anvil or vise, and using a hammer!What is the process? Remove the weights, drill out the stock rivets, and install heavier rivets with a rivet gun?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
(It) being the weight!Install heavier rivet by holding it sideways on anvil or vise, and using a hammer!
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Thanks. What kind of RPM drop would you estimate if I replaced the 4.5 with a 5.9?Install heavier rivet by holding it sideways on anvil or vise, and using a hammer!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
150 or so. But you could drill out a bit if too heavy, if you have a scale! Start with very small bit and keep going deeper until desired weight is met! If not enough, use next size drill bit.Thanks. What kind of RPM drop would you estimate if I replaced the 4.5 with a 5.9?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Fourload explained it well.. I didn’t know they changed the tip weight on the newer sleds. Makes sense now how some of you are using the original weights with xs belt and be in the rpm range.Perhaps the 240ss tune is faster than max spool 16? I know TD uses a higher base HP for their calculations compared to Hurricane.
