Adjusted my strap to the 3rd hole (middle) Any changes?
Irv
ONT. Canada
Canada
2008 40th Anniversary Vector.
1995 XLT SP (Son's)
I went to change my strap setting to the second hole today but seen it was already in there?(is that the factory setting or has it been adjusted?)
When I see it was in the second hole, I lowered it to the 3rd hole, (or middle hole)
Just curious, with doing this what all have I affected?
I am assuming a little hard steering but will it not stay a little flatter in the corners now as well?
Also, by doing this, will any suspension or other adjustmensts be required?
This lack of snow is killing me so I thought I'd play around a bit today, not sure if I made the right decision or not by playing with my limiter strap?
Your steering should be lighter not stiffer, you are taking weight off the skis by going down one hole.
Shorter limiter strap=more ski pressure/less transfer
Longer limiter strap=less ski pressure/more transfer
Usually changing any settings (front shocks, limiter strap, transfer rod)...would require tweaking of the other setting to get everything spot-on. Unless everything else was spot on and you were just looking for a little more ski pressure.
Thanks NYAGT, thought it would make the steering a little harder but thought I'd try it and see if it is what I am after?
Just curious, if you know, is the factory setting usually in the first hole or do they always come in the second?
Thanks. ;)!
Thanks. ;)!
Don quote me on this, but I believe the 3rd hole is how it comes from the factory. Meaning, you can let it out one more hole (more transfer) OR tighten it 2 holes (more ski pressure).
Maybe someone else can 100% confirm?
ragdoll said:
As I had that sled from new Irv, I can tell you the limiter strap setting was never changed.
Thanks Mike, I assumed it was the second hole from the factory but just wanted to make sure.
With me putting it to the 3rd hole, I doubt there will be much change but I am curious just the same.
I know it makes a big difference on my phazer, 3rd/middle hole is perfect for trails, 2nd hole (one set looser/longer) and it turns into a wheelie machine/cornering ski lifter that works great for off-trail.
That is what I am after, hope my Vector is the same as your Phazer! ;)!
Another idea to reduce lift would be to tighten your ski springs. Tighter springs = less sway and you'll also get smaller increments of ski pressure vs. the big change that moving a limiter strap can make.
A heavier swaybar would help too = less lean but the ride can be stiffer.
Can't speak for the late model Vector's but does anybody else think the stock ski springs are just a little on the light side? Maybe a dual rate spring...didn't the Viper era Yamaha's have dual rate springs in front?
I disagree with the bold, tightening your springs will raise the a-arms up and contribute to ski lift in the corners.
It has been written (and proven) countless times on here that the flatter you can get your a-arms the flatter the turns will be.
Mine are currently as loose as possible (without coming out or being loose if I get some air) and it makes for far better handling/cornering than when they were much tighter.
I am considering a 13mm sway bar but at this point I am not sure I want to invest anymore money into my sled due to the lack of riding time! (ex-snow) :o|
