Adjusting sag on the Apex
MXD
Boston, MA
What is the range it should be in? The manual is very vague. Is it like a motocross bike where you take a measurement from one point on the sled to the ground then sit on it and take the same measurement to find the difference?
MXD, you need to measure the spring lenght to set the sag. 1st measure the spring lenght with the rear end lifted. Then measure with you and gear in normall riding postion, this should be 40 to 45 mm less.
Pullinfront
