DeepFrz
I picked up a set of ProTaper handlebars with grips and heaters that came off of a newer Pro RMK. I've done research and haven't really been able to find a for sure answer. The Polaris heaters use 3 wires (High, Low, Ground) unlike the Yamaha 2 wire system.
Would I be able to just splice in the high wire and be good to go?
Also, seeing how I'm not near my sled atm, which wire is which on the Yamaha heaters?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you connect the high and low together not sure on the other part.
If anyone would know it is rickmeister
Rockmeister stupid phone
DeepFrz
Are you sure both? That doesn't sound right to me...you connect the high and low together not sure on the other part.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
That's what the directions said for my after market ones said and how mine have been for 2 years working great
Sent from my SCH-I545L using Tapatalk
