markyb
- Feb 6, 2015
- Twillingate, NL
- 2009 Nytro XTX
- Twillingate, NL
Looking for some help...
RSI handwarmers quit so I re-ordered from same parts place as before. This time I was sent SPI elements instead.
I remember RSI had very clear instructions on how to wire however all the SPI ones have say Red: common/ground, White: High, Black: Low.
Need to know which 2 wires to twist together, and is it safe to assume that it don’t matter which black is used as both wires on the sled side are black (cut and spliced factory wiring when I installed previous RSI warmers)
There was a previous thread asking for much the same info but only info given was “got a phone call with answer”
Any info greatly appreciated.
Dr. FeeLGooD
look in faq, theres a wire diagram in it. Connect the hi and low together.
markyb
- Feb 6, 2015
- Twillingate, NL
- 2009 Nytro XTX
- Twillingate, NL
Couldn’t find it to save my life but thanks for the info. Have them installed and working fine.look in faq, theres a wire diagram in it. Connect the hi and low together.
DeepFrz
What FeeLGooD said, when I put my Polaris ProTapers on I connected the Hi and Low wires together. As you said, I don't believe it matters which one you ground on the Yamaha two wire setup. DON'T quote me on that haha. Glad you got them wired up okay!
- 32K
