machzrobbie
Has anyone had any problems with the aftermarket head bolts out there - specifically on APEX. Ive got one that keeps pushing coolant out the coolant bottle only under hard riding(boost) - no coolant leaks, no overheating, and will hold pressure for days.
First time I put it together I figured it was stock head bolts, so we installed new gaskets, a set of head bolts and reused the original shim. Right away it pushed coolant again, so I took it down, resurfaced head, checked for cracks, new shim and gaskets. Measured block and made sure it was straight, this time it made it 300+ trail miles and then started pushing coolant again. Someone mentioned today that there was a problem with a certian headbolt out there, just want to know if anyone else had any problems like this.
This is not my sled, I did mine the same with the ARP head studs and have had zero issues with mine running same boost.
