suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
09nytro said:So they don't work well off trail you say ?suprfst said:09nytro said:So would you say the curves are close to the stock ski as far as turning effort , I running powder pro now and its alittle more effort to turn was thinking about getting curves and trying them , there mountain ski is what I want to get
Yes curves aren't much different than stock as far as effort. Defiantly turn easier than powder pros. The slp mohawks are also an easy turning ski, since I already had mounts and carbides from powder pros I just ordered skis and loops.
They(curves) are fine off trail, personally I think they have much better flotation than the stock skis. The wider skis like a powder pro do float better and turn better in loose snow. It all depends on how you want to use your sled. I will say the slp mowhak and the curves are the two best overall skis I have ran on the Procross. That's taking into account steering effort, trail manners and off trail. Hope that helps
