new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
will I have to adjust my clutch weights when I do the air box mod ??
mopar yam
- Nov 10, 2011
I didn't , I think as long as your not hitting the rev limiter ya should be ok!
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
Does the airbox mod void warranty? Should you use a power commander? What kind of hp gains do you get?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Any mod “could” void your warranty. The general consensus is the fueling is pretty rich from the factory and you can run a Can + Airbox without a power commander but a commander does help to smooth out the fuel curve and add a few ponies to the combo. Adding a header is where a fuel controller/performance flash should be done. Mine has a Can + Airbox mod and it has a noticeable lean spot transitioning from idle to part throttle, it had it stock also, just not as noticeable.Does the airbox mod void warranty? Should you use a power commander? What kind of hp gains do you get?
Depends what warranty is for. PCV Not necessarily. Would depend on other mods. AFR guage is one of best investments I made. Now I know if I need to tune. 4 st is very forgiving though. Watch engine temp if its hotter than normal surely you need to richen fuel. Flash version matters also in my opinion.Does the airbox mod void warranty? Should you use a power commander? What kind of hp gains do you get?
Lol almost a double post! I like how you think blueiron!Any mod “could” void your warranty. The general consensus is the fueling is pretty rich from the factory and you can run a Can + Airbox without a power commander but a commander does help to smooth out the fuel curve and add a few ponies to the combo. Adding a header is where a fuel controller/performance flash should be done. Mine has a Can + Airbox mod and it has a noticeable lean spot transitioning from idle to part throttle, it had it stock also, just not as noticeable.
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
Thanks guys.I don't know alot about this, I'm trying to keep it simple.Clutch and can or clutch and air box mod.Trying to figure out the best way to go.
trailtamer
- Feb 8, 2006
- Manistee County, MI
- 2014 Yamaha SR Viper LTX
Subscribed. I'm thinking about the air box mod with stock exhaust.
Jipper
- Mar 3, 2015
- Ramsey,MN
- 2016 Yamaha Viper LTX LE
Does doing the air box mod make a lot of noise when riding ?
No.Does doing the air box mod make a lot of noise when riding ?
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
I just did mod and I have a lot of intake noise. Anyone know why
Mills
- Dec 4, 2007
Cracked header is the source of my noise. No flex joint on the header like a Nytro so any stress on the header from being bolted in and secured in place by the hold down spring probably helped it crack.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Glad you got it figured out
