TD Max
Just for clarification leave the snorkel/baffle out.
I also blunted the tips of the cut out dividers with a small dab of silicone to prevent poking through.
I took some pretty detailed pics before, during, and after.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Please attach the pictures. Thanks!
stingray719
Ok I edited "Remove snorkel from the lower air opening." to "Remove snorkel from the lower air opening and do not reinstall"
TD Max
I'll see how the pics turned out and can fwd to Bill so he can edit into the first post. Grandkids are here today so we get to play putt putt with the sleds after lunch.
superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
What about the shelf, leave it in or take it out also?
stingray719
Leave the shelf in.
Alsim
- Oct 6, 2014
- LTX SE 2018
The last iteration of the air box mod has been fully tested and works slightly better than the original.
Heat pcv divider and bend over to minimize turbulence, as per first pic....
Remove snorkel from the lower air opening and do not reinstall.
Cut out are as per second pic but be careful you don't damage frogskin. This one looks a little rough as pic was taken before finish work.
If there is enough interest I can do this mod to a lower airbox and send out, or mod yours.
If I do the air box modification with mbrp can, should I do install the pc5 ?
stingray719
NOS-PRO ran air box mod and MBRP can on the asphalt racing 1/4 mile but that is a lot warmer and needs less fuel than winter riding. I would go on the safe side and add an AFR gauge to find out, and if you need a controller the new PCFC is under 300 bucks if I read right.
stingray719
Here is a link that will help with understanding what goes into modding the air flow, the string trick is an oldy but a goody.
http://www.diyporting.com/thread.html
TD Max
Here's how I did mine:
Snorkel:
Snorkel removed:
Divider Before:
Divider after:
Opening roughed:
Opening finished: The additional area of entry to the air box has increased by approx. 2/3 of what it was stock.
Note: I put a couple of small dabs of silicone where the frogskin material contacts the cut out support ribs.
Snorkel:
Snorkel removed:
Divider Before:
Divider after:
Opening roughed:
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Snorkel:
Snorkel removed
Divder Before:
Divider after:
Opening roughed:
I can not open your photo attachments.
- Apr 14, 2003
- Hessel, Michigan
Same here....unable to open Stingray
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
I was able to use Stingray's link (which I found very interesting by the way). It was TD Max's pictures that I couldn't open.
- Apr 14, 2003
- Hessel, Michigan
Oops...my bad....yup, I see TD's pictures didn't open.
TD Max
Try it now.
- Status
