RTX Meirda
I just bought a wide band O2 setup for my Apex. What air/fuel ratio should I be shooting for at different throdle positions?
blue er
buy some dyno time, but most na 4 strokes seem to like 12.5:1 give or take a bit, my tiburon liked 12.7 across the board overall
DYNAREX
i think 13-13.5 is best power
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
87 octane on the dyno anything leaner than 12.3 did not make any more HP. That's at WOT.
APEX 21
- Jul 21, 2005
- Pardeeville, Wis Northwoods & UP
I heard they come stock 12.5 to 1 air to fuel. I've heard switching it to 13.5 to1 will get you better fuel economy with no real hp loss
RTX Meirda
Does anyone know at what ratio there begins to be a power loss?
I know Ulmer has been to the dyno, so i believe the sled will not make any more power going leaner than 12.3 to 1.
What is the limit where power begins to drop?
Bigger Hammer
Hope you don't mind me putting a couple more questions on your thread, they are related, not trying to hijack thread. EFI is new to me, just trying to get an understanding of it.
I heard that when you slowly increase throttle, the A/F ratio will lean out some, but when you accelerate hard, it gets richer, is this correct? ( I heard this about EFI in general, not specific to sleds) How much does it change?
Bigwin
This is a great thread, All eyes and ears..
SledFreak
- Feb 7, 2005
- Ontario. Canada
and so is RTX Meirda avatar.....
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
170plus
- Jan 14, 2004
- washburn maine
- 2021 polaris assault 850,18 sidewinder ltx,14 nitro xtx,06 apex rtx,
at wot the efi goes richer or leaner according to the air temp in the airbox,colder air,richer efi,warmer air the leaner it goes,the adjustments you make on the pod have no effect on the wot running
Bigger Hammer
Ok below WOT, or more specifically below 7000 RPM, is the air fuel ratio around 12.3:1 stock? Or is it a little leaner (13.0-13.5:1)? I have not had a problem, but have heard of some people having a flat spot when they nail it. I realize that stock I have no control over the fuel mixture above 7000 RPM.
170plus
- Jan 14, 2004
- washburn maine
if i remember correctly,when we checked mine with the exhaust gas analyzer that stock was like 14.5 to 1,we set mine up at 13.2 to 1 which only raised the numbers on the pod by only 4 or 5,when we run the cylinder up 10 or 12 points on the pod,it was down below 12 to 1 so probably too rich for stock airbox,i havent tried any more adjustments since i put the holes in my airbox cause it never has bobbled at any rpm
RTX Meirda
OK I went out to the lake today!
I closed all of the air openings that I have added.
At WOT, the sled is 12.1 to 1 air fuel ratio. (-8 degrees C)
When I uncover my 6 bulls eyes and 2 TPI valves, The ratio is approx 12.6 to 1.
The sled feels much snapier with the airbox open. I couldn't find anyone that wanted to race me today, so I can't tell you which is faster. (I set the suspension past max transfer, once they saw me launch....no one would come near)
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
RTX Meirda said:OK I went out to the lake today!
today I learnt that you should close the TPI's when spraying nitrous...or it sprays right out the side of them...still gained me 20mph hehe...
