Anders
- Dec 12, 2020
- Jämtland
- Sweden
- Yamaha Venture Multi Purpose 2009
Hey all.
New here on the forum. Come from Sweden.
Have a problem with the Snowmobile, tried to start it for the first time since last winter.. Only getting a clicking noice. Have new battery and starter relay installed. What more should i look for?? ground??
Anders
Anders
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Where is the clicking coming from? The starter relay or another one? Have you tried jumping the two posts on the relay? Is the relay getting the signal from the ignition switch?
kirkswim
- Jan 11, 2009
- sudbury ontario
- Yamaha RXWarrior
That is what my phazer did. Check for power at your starter. It there is power then when you attempt to start the starter is bad. Mine did this when one of the magnets in the starter came unglued and destroyed itself.
Anders
- Dec 12, 2020
- Jämtland
- Sweden
The clicking is coming from the starter relay. Im no mechanic or electric wizard, so not sure what to look for in the system...
Anders
- Dec 12, 2020
- Jämtland
- Sweden
Havent looked at the starter, might have to do that.. No mechanic though..
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Use a tool like long nose pliers to jump the two posts on the starter relay. If you get a big spark but the starter doesn't engage, the starter is probably borked. Make sure your battery is fully charged or in good condition. How old is it? If it has any age to it, I'd look at replacing it or at least try a jump pack.
Anders
- Dec 12, 2020
- Jämtland
- Sweden
I worked out the problem with the clicking sound i had on my Yamaha Venture Multi purpose. The Main fuse was corroded....Use a tool like long nose pliers to jump the two posts on the starter relay. If you get a big spark but the starter doesn't engage, the starter is probably borked. Make sure your battery is fully charged or in good condition. How old is it? If it has any age to it, I'd look at replacing it or at least try a jump pack.
Now i have a new problem?? I think i flooded the cylinder while trying to start it, how do i get the spark plugs out to drain it?? looks impossible to get the seat,tank away...
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
You have to take off the rear seat, the tank cover and the front seat, then the fuel tank. It's intimidating the first time but it gets easier the more you do it.
Anders
- Dec 12, 2020
- Jämtland
- Sweden
Thx for the info, i knew it was something like that. Just have to bite the bullet..Have to move it to somewhat warmer place first. So anoying since we got 3 feet of snow a few days ago.And trails need to be done..
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
And while you're there, inspect the exhaust donuts. They can either burn out, leaving just mesh, and/or the clamps can get loose.
Anders
- Dec 12, 2020
- Jämtland
- Sweden
Hey.And while you're there, inspect the exhaust donuts. They can either burn out, leaving just mesh, and/or the clamps can get loose.
i got so far as getting to were the spark plugs are??, dont look as any I ever have seen. Am i suppose to tvist the "thing" after removing the wire/contact? And if so how does it work
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Just going from memory since I don't this sled anymore. Remove the connector and bolt on each coil and then pull them out. The plugs are deep inside the hole and are a smaller hex than the normal 5/8".
Anders
- Dec 12, 2020
- Jämtland
- Sweden
Ok. Thx.Will try that, I saw somewhere that you needed to twist the coil,tried that and nothing happened... Want to tread careful, have a tendency to break stuff...hehe
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Yeah, you do have to twist and pull at the same time.
Anders
- Dec 12, 2020
- Jämtland
- Sweden
Thx for all help with ideas on the problems with my Multi purpose. I got new sparkpluggs in and it started directly, sat sunday the club will prepare the over snowed trails and ill be joining..Yeah, you do have to twist and pull at the same time.
Anders
- 22K
- 7K
