outofbounds
- Feb 19, 2009
- Leavenworth and Bellevue Washington
The Spring issue of American Snowmobiler has a decent write-up called "Pounding the Powder".
They test the usual suspects in the 800 mountain class but threw in a Nytro MTX in order to have all of the manufacturers represented.
Stock MTX held its own - even placed second in their Hill Cross Course test.
No big surprises - they feel that the Yamaha would run vertical with the 800's if it lost a bit more weight and had a few more ponies under the hood.
Anyway, I wasn't sure how many of you see this magazine so I thought I'd let you know that there is a pretty good article there.
Southern Renegade
- Jan 27, 2009
- Rock Island Arsenal, Rock Island IL
- 2009 Polaris RMK Shift 144
Good article but it was the only one with 162 track and it was a good three seconds behind the others up the hill. needs some more horse and time to pull some heavy steel off since Poo and Doo figured it out
Why compare 600 class sled to 800's?
outofbounds
- Feb 19, 2009
To see how they compare?
Do you want to see a comparison between a 500 and a 1000? Stay tuned next month. lol
pwa
bottlerocket said:Why compare 600 class sled to 800's?
Because Yamaha has nothing in the 800 segment... Sad but true. An 800 is not always better than a 600 but when you need the power you need it. Simple as that.
pwa said:bottlerocket said:Why compare 600 class sled to 800's?
You anwsered my question with " Because Yamaha has nothing in the 800 segment..." thanks
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I just dont understand why SOOOO MANY people get upset when they hear the Nytro was still slower than the 800's!! ITS NOT EVEN IN THE SAME CLASS!! bottlerocket, you nailed it imo..
It seems im crazy ~ thankstapex_07 said:I just dont understand why SOOOO MANY people get upset when they hear the Nytro was still slower than the 800's!! ITS NOT EVEN IN THE SAME CLASS!! bottlerocket, you nailed it imo..
- 10K
