Any oil with the SG API rating has the Zinc and Phosphorous additives mentioned in the Mobil article above.That said there are very few that have it.Not all Amsoils do.The 0w40Yamalube doesnt.The Zinc and Phosphorous were removed from many oils for emissions.Many will swear it can make the difference in survival of cams.I will be looking for Amsoil with low enough viscosity and that rating or will use Yamalube like I did for my end of year change.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the amsoil guys at the novi show couldnt answer me whether or not the 0w-30 is wet clutch safe..
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
sj said:the amsoil guys at the novi show couldnt answer me whether or not the 0w-30 is wet clutch safe..
Where are you using it? In a bike?
The Apex starter is not a wet clutch, it has lock pins...I think!!
I use the Amsoil in all my Quads and bikes.This grade has the SG rating.On the Cannondales I have never washed out a cam many,many other owners who dont run Amsoil have had cams wash out.Yes some of the cams are subpar but I am not taking any chances since many times when cam lobe goes it is hardly noticable till valve floats and then drops.Need to research for correct Amsoil for my sled and I trust Yamaha's cams much more especially with the lighter valve pressures the Ti valves allow but you never know.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
per yamaha's chief service rep says..."dont use synthetics ...weve seen the wet starter fail due to this and it's not covered under warranty"
87gtNOS
- Nov 30, 2005
- Toronto
sj said:per yamaha's chief service rep says..."dont use synthetics ...weve seen the wet starter fail due to this and it's not covered under warranty"
I haven't had an Apex apart, but am pretty sure I saw Ulmer say it wasn't a wet clutch! Perhaps when I get a minute, I'll look it up!!
I would be far more concerned over any one-way bearings wearing before starter clutch.Simple replacement in most cases anyway if starterclutch were to go.Speaking of clutches I have 2seasons and counting on Cannondale driveclutch and other than the tabs on plates getting bagged they are fine.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
cannondale27 said:I would be far more concerned over any one-way bearings wearing before starter clutch.Simple replacement in most cases anyway if starterclutch were to [ quote]
that's what I thought...yam sev rep says to replace,complete motor disassembly required !!
Mtn-Track
I think Gary (NosBoy) plays on the 2-stroke side, so I brought one of his postings over here (from 10-22-07); Oil seems to be a passion of his, and so is patriotism!
Do a search on the 2-stroke side for him and you'll get the picture about oils..............ENJOY!
I was at the SNOWSHOW in MILWAUKEE on Saturday and I had to work SUNDAY,,,,,but,,,, HERE GOES!!!!!!! CITGO MAKES YAMALUBE along with about 23 or 24 DIFFERENT brands (including TEXACO products) of 2 stroke oil.... IT COMES from the SAME MILLION GALLON tank (all 23 or 24 brands!!!)..... YAMAHA motor company pays some little japanese dude to throw a little pill in the yamaha jugs to call it YAMALUBE (please don't believe that)!!! Thats how YAMAHA can charge DOUBLE for a gallon than you can pay at WALMART!!!!! VENEZUELA owns CITGO (hugo CHAVEZ)!!!! Venezuela wouyld like to BLOW AMERICA to smithereens!!!! KEEP SUPPORTING TERRORISM all you guys who support yamalube..... ANOTHER THING........ CHIQUITA BANANNA company BRAGS on CNN that they support (give money) to TERRORIST GROUPS that TERRORIZE AMERICA!!!!! You people better get your heads out of the SAND and read whats going on in the world!!!!!! Opec (foreign oil) is about 10% of our AMERICAN oil needs... EVERYBODY seems to think that without SAUDI ARABIA we would be MINCEMEAT!!!!!! NEEDLESS TO SAY,,, we GET ABOUT TEN PERCENT (10%) from overseas..... VENEZUELA is also considered overseas oil...... I dont buy CHIQUITA banannas OR use YAMALUBE!!!!!! I even have a HARD TIME BUYING JAPANESE snowmobiles,,, but,,, until the americans make something WORTH BUYING,,, I'll keep supporting YAMAHA!!! Gary Oles nosboy
So does that mean you use american made oil???!!!
Correct me if I'm wrong, Sj, but isn't the 0-30 yamalube synthetic?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
nope......dino
cool, I didn't know
rehm70 said:So does that mean you use american made oil???!!!
I think it is semi synthetic myself but I could be wrong.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
It is a semi-synthetic...
As for Amsoil I've been running it in all my 2-stroke and 4-stroke sleds and will not use anything else. Best oil you can buy
Yes 0 - 30 Yamalube is Semi Synthetic ...There are guys on here with alot of miles on there sleds that use Amsoil without any problems...I am using Amsoil and it $1.80 a litre cheaper then Yamalube...
