one thing i noticed when putting my sled back together, the clamps were wore thin on the edges. If you are replacing donuts with these clamps, they will not squeeze the donut as much. The clamp is made so it will only tighten so far.
i installed rx1 exhaust, it fits good, the tips wont fit on unless you weld the apex stlye flanges on to the pipes. I used rx1 tips. you need to space out the top bolt about 3/8 and bend the lower mounts in about 1/4 then they go right on. the top bolt needs to be longer for the spacer.
the rx1 side covers will not fit into the apex style tail light cover without alot of cut and fit and then the lower side will never match up. too bad, the rx style looks better but the apex light looks better.
