Kråkan
The only real question is...
Why havent this already been done by Yamaha?? I dont want to start welding in my new sled...
08 FX Nytro lover
Nice job!nytro23 said:Install Ulmer's oil lite bushings, weld upper and lower a arm bracing and weld brace on sub frame and you'll never have another problem. You can hit a tree with hardly any damage ( ask my partner !! )
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Would it be possible to fabricate something that simply bolts in between the front a-arm bolts and the rear a-arm bolts just to brace the front mounts to the rear??
08NitroRTX
nate007 said:Would it be possible to fabricate something that simply bolts in between the front a-arm bolts and the rear a-arm bolts just to brace the front mounts to the rear??
Yes!
A piece of strap steel 1" by 3/16" notched and drilled to fit between your front upper a-arm mounting points. (you will have to relocate the electronics that are there but it's easy)
And the lowers A-arms mounts can be braced as well.
nate007
- Dec 25, 2006
- Iowa City, Iowa
I was thinking more of a block of aluminum that would fit between the thin steel plates, and merely require long bolts that go completely through the a-arms from front to back. Keep it something that can bolt in, so that the average rider can have a stonger sled, with out the expense and hassle of welding and painting.
gormleyflyer2002
nate007 said:I was thinking more of a block of aluminum that would fit between the thin steel plates, and merely require long bolts that go completely through the a-arms from front to back. Keep it something that can bolt in, so that the average rider can have a stonger sled, with out the expense and hassle of welding and painting.
thats a really clever and interesting idea......have you looked at this already..?
08NitroRTX
Wasn't a tree it was a log hidden under the snow... But it's your story, Tell it however you like.....
