Another Secondary Question.
yamagone
Essex, Ont. Canada.
Canada
18' Sidewinder
LOCATION
Ontario
It's my first roller secondary. Is there supposed to be side to side play on the shaft? I put it back on today and noticed there wasn't any play.
Mine had play back & forth. Looked like 3/16"
Thank you. I was hoping for more replies not that I doubt you.
I doubt myself. Don't blame you. I'm not one of the pros here. But mine was shifting back & forth.
Maybe as it climbs the helix some of the float gets taken away. I'm positive it's something like that.
Well....I'm wrong. I just cinched mine down. Doesn't move. Hmm......
No play in the driven when bolt is tight
Did you put the belt on?
With the belt on it loads pressure on the helix and then your clutch will float. Providing you do not have an after market belt adjuster.
I'll throw the belt on it tonight and see if there's any movement, thanks.
Right you are. I put the belt back on and now have the play I was looking for, thanks.
