yamaha06
Does anyone know if the Thundercat secondary jackshaft is the same as the sidewinder jack shaft? I had a company remove the bearing from the shaft and they ended up screwing up the splined section on the secondary side. The end of the shaft was swelled, looks like they may have hit it with a hammer. So they tried to grind the splines down and clean them up. The secondary seems to slide on but they seem to kind of stick when going through the helix.
I ordered a new shaft from the dealer and it was back ordered, was supposed to come in today but now they are telling me maybe Feb.3
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
No they are different on the end we’re the secondary clutch goes because of the Yamaha vs Cat clutches
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Have you tried to order the shaft assembly that comes with the mount and bearing?
yamaha06
No I had just tried for the shaft. Was $205 for the shaft.
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
Try ebay
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
I bet Travis @ Barn of Parts has one. Give him a call.
yamaha06
Well I filed the splines some more and the secondary now slides on the splines right to the snap ring nice and smooth. Doesn’t seem to be any play between the clutch and shaft so I maybe good now.
Not sure with the way the shaft was swelled a bit and filing if it would be a hair shorter than it once was but I don’t think it will really matter.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Be careful whom you let work on your sled, lots of knuckle heads out there. They obviously beat on the shaft with a hammer. Next time ask them to press it off.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Different shaft ,different bearing.Does anyone know if the Thundercat secondary jackshaft is the same as the sidewinder jack shaft? I had a company remove the bearing from the shaft and they ended up screwing up the splined section on the secondary side. The end of the shaft was swelled, looks like they may have hit it with a hammer. So they tried to grind the splines down and clean them up. The secondary seems to slide on but they seem to kind of stick when going through the helix.
https://ty4stroke.com/threads/jack-shaft-sw.154170/page-2
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
X2.Be careful whom you let work on your sled, lots of knuckle heads out there. They obviously beat on the shaft with a hammer. Next time ask them to press it off.
Or it works pretty good whit this home made tool. Cold shaft and bearing, little heat on the brace.
yamaha06
yes exactly, I could of beat it off with a hammer at my house, they were supposed to press is off but that obviously didn’t happen. Live and learn!
yamaha06
Just a quick question. I noticed when putting the jack shaft back in, the two gold bolts that hold the mount on. The bottom bolt has a hose that is touching the nut on the backside. I would assume it’s fine and shouldn’t rub at all since nothing should be moving back there.
Turboflash
- Mar 18, 2019
- Southern MN
IMO, should be ok as long as it's secure in the holder so it doesn't flop around.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Hose is just the gas tank vent anyhowJust a quick question. I noticed when putting the jack shaft back in, the two gold bolts that hold the mount on. The bottom bolt has a hose that is touching the nut on the backside. I would assume it’s fine and shouldn’t rub at all since nothing should be moving back there.
