Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Seems like the relay stuck on and i fried my starter. There was smoke coming from the + terminal on the battery.
I now measure a direct short between the starter positive lead and ground. Can anyone verify how many ohms Im supposed to measure there?
Question is, even with the relay gone.. why do i get code 12 (crankshaft position sensor) and code 46 (ecu voltage) in the display?
All fuses are ok, and fuel pump goes like it should.
Where do i start? (Except ordering a new starter and relay)..
I have tried to replace the battery, but still get the same fault codes. And no luck jumping the starter relay either.. So its probably shot.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
A new thread? lol
I posted a bunch of info on this here: http://www.ty4stroke.com/viewtopic.php?t=118072
As far as your codes, there is a good chance that most will clear once you start your sled.
Your stator has a good chance of being cooked also.
You can test the starter with a 12v battery and jumper cables, however, it IS most likely a dead short.
Just do a quick touch of the final connection, a short will throw a BUNCH of sparks, a good starter will spin and throw some sparks when connected.
(You will definitely know if it is a dead short.)
Once you replace everything, make sure you KNOW you fixed the cause so you don't have to replace it all again in a week!
Rock
Rock
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Yep, its a dead short. And there definately was no cranking when i shorted out the relay..
The relay is stuck in the ON position, so I guess thats the reason the starter failed? Dont you think?
I have a new starter on the way already..
This happened on my backup sled… On my turbo sled i have the starter saver… guess I should have had one on this one too….
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
The relay could have stuck due to a failed key switch also, would replace it too.
The relay will usually weld itself closed when the switch sticks.
yamanytro121
Yea i CPS error when my starter failed also. i think you get that once your ecu reaizes your starter should be turning and the engine is not turning.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Thanks for the info guys.
I ordered a new starter last night. And I will change the key switch as well. Plus check all relays and the stator.
I am surprised the battery held up being shorted out completely for several minutes..
I will run a battery test on it before i install it again, but at least it took charge and reads normal voltage.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Can anyone tell me the purpose of diode "11" in the circuit diagram.
Part number: 4WA-81980-00-00 Diode, Assy.
Is it to protect the ecu for possible overvoltage?
How do i measure it? It does not respond to a regular diode tester.
The stator values was good. And Im gonna test the rectifier at work tomorrow with a 3-phase variac.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
It is a Transient Voltage Suppressor Diode.
It protects the ECU against the Inductive Voltage Kickback from the starter relay when the Magnetic field collapses.
Test by applying a Current Limited voltage across it.
Do not know the exact specs, but should be 18-25V or so for turn-on.
One direction will be open no matter what. (Until you kill it anyway.)
The other direction will turn-on with enough voltage supplied.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Thanks Rock!
I will test both the relay and rectifier at work tomorrow. Hopefully they will turn out good.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
The diode opened at 20 volts.
The rectifier also seems to work. 14.8 VDC output with no consumers.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
Awesome!
For everyone else reading this, By "opened", He means it let current through it.
Rock : )
Rock : )
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Swapped the starter and ignition switch yesterday. Codes went away and everything seems fine.
I found I had to loosen the subframe and lift it a little to be able to bend the engine far enough to get the starter out. Definately a two man job.
I will install battery quick connectors on my sleds, so i have the possibility to disconnect the battery if the starter should hang on in the future.
fxnytro1050
if you look at the front of the nytro engine it had a perfect place to put a small shackle through. I used that and an overhead jib crane for tilting my enigine but im sure you could use another sort of method to tilt it for a one man job
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Yep, thought about it, but already used the jib crane to lift the front up in the air. It was a much easier job than expected
