Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Seems like the relay stuck on and i fried my starter. There was smoke coming from the + terminal on the battery.
I now measure a direct short between the starter positive lead and ground. Can anyone verify how many ohms Im supposed to measure there?
Question is, even with the relay gone.. why do i get code 12 (crankshaft position sensor) and code 46 (ecu voltage) in the display?
All fuses are ok, and fuel pump goes like it should.
Where do i start? (Except ordering a new starter and relay)..
I have tried to replace the battery, but still get the same fault codes. And no luck jumping the starter relay either.. So its probably shot.
