Sportsterdanne
On a Nytro is the engine brake reduction controlled by the ecu ?
If so, is it possible to reprogram the ecu to reduce it even more with a reflash ?
I think the engine brake is one of the major issues that the make the sled feel heavy compared to a two stroke.
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
I agree, the engine breaking, even after 6 years on my nytro, still gets to me. its nice on tight trails and dont have to use my break as much but in any amount of powder if you let off the gas it takes a nose dive. I too would like another "fix".
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
Isn't the clutch the reason?
natedawgedog
- Feb 5, 2011
- DLG, Ak
its the engine, its already being reduced by the ecu but not entirely, http://snowmobiles.yamahablogs.ca/2007/04/23/gimme-a-brake/ , you can tune alot of it out with the clutches but its still there.
Molson
- Mar 31, 2015
- Sudbury
- 2012 Nytro mtx 162"
Yep my second year with the mtx
In the standing position I fil like
I'm going over the bars lol
But still wouldn't trade for a coupeDevile
radianguy
- Jan 1, 2007
Set of 14.5 mm rollers and YPY primary spring will almost completely get rid of the engine brake, and a nice little boost in performance too!
Cheap mod with proven results.
Molson
- Mar 31, 2015
- Sudbury
Just got back from a good ride back of the water shed and it is kind of a pain in the but... I will for sure Look in to that... a happy new year to everyone and let it snow
jason22
- Feb 28, 2014
- Newboro Ontario Canada
- Yamaha Nytro
What does the 14.5mm rollers and YPY primary spring do
Can I get from Yamaha Dealer?
Part numbers?
Higher clutch engagement?
How does it accually get rid of engine breaking? Is there an forum or thread on it?
Not fond on Nytro at low speeds 0-40 very touchy throttle and jerky.. not good in very tight trails
Will this mod make it like a a 2 stroke? Left off gas and you glide?
Thanks any help be great
Part numbers?
radianguy
- Jan 1, 2007
Been discussed about a lot, but 14.5 mm rollers act similar to adding more weight to the clutch. The YPY spring along with the rollers lower engagement taking the jerky motion out of the low speed cruising it also let's the sled coast better when off the fuel.
14.5 mm rollers 8CR-17624-00-00
YPY SPRING 90501-581L5-00
Available from yamaha dealer.
The rollers are used in the 4 cyl 4strokes and 3cyl 2 strokes except srx.
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Thanks for posting the part #'s. It saved me having to look them up. I am going to try that set-up. I ordered them from Port YamahaBeen discussed about a lot, but 14.5 mm rollers act similar to adding more weight to the clutch. The YPY spring along with the rollers lower engagement taking the jerky motion out of the low speed cruising it also let's the sled coast better when off the fuel.
jason22
- Feb 28, 2014
- Yamaha Nytro
Thank you for posting.
I did find some postings on setup.
There looks to be a kit. From Schmidt Bros also
Comfort kit or the Stage 2 kit.
Looks to have good reviews
Has anyone tried the kit from Schmidt Bros ?
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Lots of people tried and like the Schmidt Bros clutch kit but it's more or less the same as the 14.5 mm roller and YPY spring set up but costs $30 more
jason22
- Feb 28, 2014
- Yamaha Nytro
Just looked up part number for rollers
Didn't realize Yamaha had a wide range of years for inter change of parts considering rollers are from 2 stroke.
Sounds like it be wiser to go Yamaha if you wanna save alittle cash
Any special tools needed to change rollers and spring?
Can you do it on sled or have to remove clutch
From sled?
From sled?
You can change out the rollers and spring with the primary still on the sled.
jason22
- Feb 28, 2014
- Yamaha Nytro
I found a TY tech video on YouTube they changed weights and spring in 2011 Apex.
Looked pretty easy for most part
Thanks Steiner
Thanks Steiner
