Antifreeze leak 2010 Vector
vmaxdlx
I'm leaking antifreeze on my 2010 vector. seems to be coming from the area behind the front heat exchanger. I removed the inspection plate that you remove to change oil, and found a mouse nest in there. removed it and still can not see much in there.
Wondering if my best bet is to remove the plate(there are a ton of rivets to remove) so I can see if the mice chewed on the hoses.
Have you recently rode, or topped off the reservoir?
Or you just noticed the leak pre ride inspection?
Ok. Because the overflow hose drains into the bellypan, I'd be positive it's an actual leak and not just blowing some out if overfilled or got a little hot.
