bleedyamaha
- Sep 28, 2013
- Northern Iowa
Wife was riding her Vector. We came to a stop and could smell antifreeze. Reservoir and coolant tank were empty. Could see fluid at bottom of split. Before the ride Ii filled the reservoir tank to proper level. Coolant check light didn’t come on but you can smell antifreeze for 78 miles. There was some antifreeze around the coolant tank area. Could the radiator cap be bad ? Can I pressure test through the reservoir?
Yes you can pressure test thru the cap at the resi. Maybe you have a loose clamp.Wife was riding her Vector. We came to a stop and could smell antifreeze. Reservoir and coolant tank were empty. Could see fluid at bottom of split. Before the ride Ii filled the reservoir tank to proper level. Coolant check light didn’t come on but you can smell antifreeze for 78 miles. There was some antifreeze around the coolant tank area. Could the radiator cap be bad ? Can I pressure test through the reservoir?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I had a similar problem that turned out to be the head gasket. Not finding an actual leak, put the overflow hose into a bottle and see if it catches the coolant. Mine would blow out coolant whenever I would romp on the throttle.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Check waterpump area on left side of engine.
If the seal leaks antifreeze will come out the weep hole on the waterpump.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Thanks everyone. I vote for Mr Sleds suggestion. Lesser of all evils. The only fluid as in drops were around the reservoir. The odor was there when you stopped.
