antifreeze leak
smoothride
belleriver ontario canada
tonight i was checking my spark plug's i put some pressure on the tube on top of the engine and the o ring started leaking antifreeze and then stop. should i change those o rings for those antifreeze tube's. I did pressure the coolant system an it did not leak.
You may of made a gap when pushing on it, if it didnt leak when you pressure tested it then it should be fine.
thank's APEX 06. The o rings are on the tubes going into the valve cover.when trying to get the spark plug caps off i push down on the antifreeze tube which move a bit which leak a bit.
