kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Just remove the bolt and it pops off? Is it backwards threads or anything? What TQ to use when replaceing? Any locktite?
I got some belt rope wrapped around the jackshaft and speedo pickup from a anniliated belt that blew on saturday and I want to remove before riding.
Thanks!
Thanks!
No backwards threads - remove bolt and it pops off. there will be a collar on this inside. On the ouside there will be a washer that needs to go back over the wideast diameter (don't pinch it between the other washers and the collar)- the other washers tighten up against the collar. You should have a little in and out play with the clutch.
46 ft lbs and no loctite according to the yam tech manual.
kinger
- Jan 17, 2005
- Clear Lake, IA
Awesome thank you!
pat the rat
- Mar 13, 2006
apply the parking brake,helps the clutch not to turn
kinger
- Jan 17, 2005
- Clear Lake, IA
<<taps EASY button>>
Well that was easy takes all of 2 mins, here i was all these years scared to touch the thing! Thanks guys!
carfull with the 46 lbs , I bent and cracked my aluminum bolt collar
kinger
- Jan 17, 2005
- Clear Lake, IA
Mmm... mine just snuged right in and gave me now issues. Thanks for the warning though!
