Shivesy
I plan to inspect the (speedometer) bearing and the jackshaft bearing for for lubrication this weekend. I've read on previous post that the secondary clutch needs to be taken off to proceed with the inspection. What do I need to do to remove the secondary? Thanks: Ronnie
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
take the belt off and remove the bolt,sleeve and shim stack (keep together) slide her off..
Wartsnuff
Shivesy said:I plan to inspect the (speedometer) bearing and the jackshaft bearing for for lubrication this weekend. I've read on previous post that the secondary clutch needs to be taken off to proceed with the inspection. What do I need to do to remove the secondary? Thanks: Ronnie
this is a sealed bearing is it not ?
or is there a grease fitting on the jackshaft ??
cheers
Red2003
They are both sealed, but you can just pop the seals off, clean out the brown gunk, and put in some fresh grease. Then pop the seal back on and you're good to go until next season.
