Anola09nytro
Was taking apart the primary last night and going to install the new Ulmer kit I bought. When I got to the spring it was in two pieces. I'm fairly new to sledding and was wondering if this a common thing or if there is something I should be looking at that might have caused this.
All feedback is welcome.
2009 nytro rtx se
2009 nytro rtx se
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
anything is possible, how many miles on the sled?Anola09nytro said:Was taking apart the primary last night and going to install the new Ulmer kit I bought. When I got to the spring it was in two pieces. I'm fairly new to sledding and was wondering if this a common thing or if there is something I should be looking at that might have caused this.
2009 nytro rtx se
check the condition of all the moving parts, anything binds while the spring is out? how do the faces of the clutch sheaves look? how did the clutches perform before the sled was put away for the summer? its uncommon for a yamaha clutches to be problematic or break for that matter.
if the primary looks good aside from the spring breaking I would say dont worry about it. if you have any other red flags on this primary during your inspection you should probably let someone at your yamaha dealer to take a closer look into it for you.
have you looked at this? and read the comments, its very helpful
http://www.ty4stroke.com/viewtopic.php? ... sc&start=0
Anola09nytro
3000miles on her
Nothing binds, and the faces are smooth no groves or anything I can see or feel.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Had happen and I think it was just ware that did it.
09nytro
Yes
Ffbsy
Spring
All Yamaha clutches are very un problematic but the springs can always break. Have had happen on a few other sleds just not my nytro yet
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Yes, primary and secondary springs do break. All springs have two heights that you want to check. The first is called the "free" height and the second is the intsalled height. the Free height is the length of the spring when it is not intalled. the installed height is just that, the length of the spring after it is installed. Know what both are because if either of them change by 10% or more you have a problem. I have seen primary springs take a set after only two years meaing that I measured the free height when new and then again two years later after taking it out of the clutch and remeasuring finding the free height had change about 12% making the spring much less affective and changing the overall shift characteristics of the clutch. I recommend changing primary and secondary springs every two years. If you ride hard and get your clutches hot often then I would suggest changing them every year.
Mills
Mills
Off Trail Mike
Gone Riding!
- Dec 26, 2009
- Bathurst, NB, Canada
- MTX
X2 .... springs break and springs definitely fatigue after a while. I have a Tundra 300F the kids use (monster 20HP) and while driving it one weekend noticed it was very slow to backshift. Took apart the secondary and although the spring was in one piece, it had gone completely soft. 1000 miles on the sled.
Both primary and secondary springs are definitely worth checking from time to time, and easy to include in your regular clutch maintenance.
OTM
OTM
