anyone ever had a rx cylinder repaired at millenium tech
oh yea jim i talked to them.they said everthing that they took out they sent back to me,and if i was missing anything that it was missing when they got it,what bs.just pm'd turk and it looks like he had the same problem.lucky for him cpr had some extras.i called jeff,dosen't have the 1 i need.
Who are you talking to at Millenium?
talked to scott this morning and just talked with kurt.kurt said to call a salvage yard.so worked up right now the top of my head gonna pop off.
So are they suggesting it was sent back with your block and that you've since lost it?
wantboost said:
they said everything that was taken out was sent back.if it's missing it wasn't there when they got it.
Leave it for now and I'll give you an update later this aft. I spoke with Millenium and am working on something to resolve the issue.
I have a restrictor for you. I cut a piece out of a hurt block and then tapped it out from the backside. I need to talk to Millenium again tomorrow morning - there may be a bigger issue here than just your own cases. I also need to mic this thing before I send it to you. PM me your address and it will go out tomorrow,
Jim
jim just pm'd my info.can't thank you enough.just wondering what are the other issues.i think its best if someone can make these things so this won't happen again.
Had mine done also this summer.all four oil restrictors was between the foam in the bottom of box.Had to look four times before I found them.They do not put them in a plastic bag .What is that small 0.314 for ?All the other parts for hose connections I JB it and tap it in .
i did get the four oil restrictors back.that small .314 brass restrictor is for the carrier bearing.i would have never known it was there if it wasen't for lakercr's pics.big thanks to him.do you know if yours was there shadow?
It wouldn't have been there. No upper case that went to Millenium would have come back with it.
Millenium dips the case in nitric acid as part of the Nicasil process and nitric acid dissolves brass. This was the 'bigger issue' I mentioned a few posts up. I'm sending the restrictor to Millenium today for them to mic and replicate.
Going forward they will be shipping the case back with a replacement restrictor that they'll make on-site.
Wantboost - Kurt @ Millenium will be forwarding it on to you 1 day after he receives it. I was going to send it to you this a.m., but if you can hold off another day it will help Millenium (and a lot of customers) out.
You don't owe me anything for the part.
jim sounds like some people maybe running around without this restrictor.looks like you have solved a major problem for us guys.can't thank you enough.
Your right, guys like Jim and the rest of these guys makes it alot easier for the rest of us on here..Thanks to all you guys!!!
