MXD
I haven't even ridden my new Apex yet and I'm hearing of darting problems. I plan on installing some 8in Executives and either 144 or 168 studs before I even hit the snow.
God, I hate being a nuerotic fool
Swiss Sledder
Take a look at this tech tip at the link below. Very inexpensive solution to darting problems.
http://www.totallyamaha.com/snowmobiles/aaTECH/darting.htm
shim the skis. It works every time.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Been there, done that, still not as easy or smooth and dart free as dual runners.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
try BRP pilots...we just setup buds GT with them for $75 bucks total swapout..i have another thread with whats involved for swap.Very easy and look nice on the GT....
go to this thread for info on the pilots swap...
http://www.ty4stroke.com/viewtopic.php?t=20071
hope this helps..
Dan
hope this helps..
Dan
snowbelt
- Mar 15, 2005
vice108 said:shim the skis. It works every time.
Did it last week. This week no dartin'. It works!
KubotaOne
I have an Attak. First time out was yesterday and mine is darting badly. Not sure if I should go with dual carbides or try the shims.
Be sure to check the ski alignment - should be 1/4 inch toed-out with the clearance taken out of the system. I attach a rubber bunjie cord between the ski tips (slight tension) when I measure the alignment.
MXD
Swiss Sledder said:Take a look at this tech tip at the link below. Very inexpensive solution to darting problems.
I might be asking alot but does anyone have any pics of the mod? I want to make sure I understand it. I think my plan will be to make the shims, tap a couple small holes and bring them with me on my first ride. If I dart, I'll whip them in trailside.
Swiss Sledder
I would just do the shims in your garage and get it over with. There are so many people that have done this successfully.
You can see some pictures of it at the link below.
http://www.bergstromskegs.com/oui/darting_solutions.htm
KubotaOne said:I have an Attak. First time out was yesterday and mine is darting badly. Not sure if I should go with dual carbides or try the shims.
There's a reason the shim trick is in the tech pages at TY. It's because it works! Give it a try - it's free. Dual carbides will also reduce darting - but they push in the corners and rob you of speed.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Vice108
I agree with your statement of dual carbides pushing in corners, but damn they are smooth, in all conditions !! I use to shim my skis, learned that in 97 from my Yamaha dealer!!
gotspeed24
u guys talking about the woody doolys ?
Swiss Sledder
Yep, doolies tend to push in the corners. Trust the other members on this and shim the skis. Nobody believes something so simple will work until after they have tried it.
APEX 21
shaper duallies are suppose to hook up better
- 12K
