mdkuni
Anyone fit 2 RX-1's on an 8 foot wide trailer? I am looking at a used trailer right now and was curious if two would fit?
QCRider
I would be shocked if they fit. I have a 101", and there isn't much room to spare.
mdkuni
According to the specs the sleds are 47.5 inches wide. So I should have 1 inch to spare! Unless they are not truly 96 inches wide......
jim-bob
you'll need a 102 and if you get one with a cover try to get a 12 footer/ you'll love it/ later
grumpysanta
I have a triton 10 foot closed and they just fit so at 102 wide yours would not fit on 96" and you would be advised to get 12' in case you get a buddy with a warrior. I wish i got 12 because i had to change my mind to a rx1. hope it helps
mdkuni
Thanks for the replies guys!
What about an RX-1 and a 98Vmax?? Does anyone know the width of the VMAX?
jimmie d
The reason they are tight on an enclosed is that the mount for the top interferes except for the Floe top which does not have the same problem. You may just make it but forget updating to aftermarket skis. Get a 102" X 12'.
jIM
jIM
yamawarrior
I have a 101"wide and have no problem fitting my warrior next to any sled (97-04)
LazyBastard
Point them in opposite directions and you'll have TONS of room to spare. I can easily fit two sleds on my 6x10.
NY_Nytro
A Warrior & RX-1 will fit on a 10' x 101" with a Bearcat cover with no problem.
grumpysanta
hey lazybastard if you every get caught with your sleds like that on black ice with a side wind you will never do that again, i am speaking from experience
LazyBastard
You should always strap your sleds down to the trailer firmly, both at front of sled and back.
RobX-1
- Coldwater, OH
I'll have to confirm the size but I'm almost certain that my Triton trailer is an 8'x10' with a Blizzard top and we were able to get my RX-1 and my buds Ski Doo Renegade facing the same direction. We had to make sure it was almost all the way up and it was real close when we shut the top but they fit.
Sled Dog
LazyBastard said:Point them in opposite directions and you'll have TONS of room to spare. I can easily fit two sleds on my 6x10.
Do you put yours or your buddies sled so the windshield catches the wind. LOL
NY_Nytro
It seems the tongue weight would be way light causing the trailer to be squirrelly.
