Yamaha Man
Hey guys,
Im going to buying a 136" extension kit from Ulmer and I was wondering if you guys bought clutch kits for your Apex's after you extended your track/rails to 136"???
If so, what did you get?
If not, how does your sled run and perform? Still have good take off, etc.?
I have an '07 Apex RTX
Thanks in advance!!
Thanks in advance!!
Yamaha Man
Anyone out there with a track extension??
TTT
TTT
Kevin Garceau
didnt do the extension...but have loved my Ulmer clutch set up from day one.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
It's not an Apex, but I did extend my '06 Nytro. Ulmer was able to tweak the clutch kit to work with the mods I did. Works great!!!!
Yamaha Man
From what I've read, it seems Ulmer has a great clutch set up! I have heard Dalton and Proline have a very competitive set up also.
Fast_Eddy
- Vanderhoof (area) Canada B.C
- www.sledwest.net
i have the ulmer kit but i have changed the springs.it works good. im about to turn it into a 136. soon as we get snow i could let you know how it is
schmeg
I went with 23/39 gearing, white spring in the secondary.
Yamaha Man
Thanks guys!!
I bought a 136" by 2" Challenger off Ebay last week and bought the rail and tunnel extensions from Ulmer too. I might cut the challenger down to 1.75"...just because that would be plenty. 2" might be a little extreme, I just like how strong and sturdy the lugs are on the deeper lug tracks.
I have a stock 22 top gear on my Apex because its an RTX, so I predict that will be ok, and I wont loose much because its already geared so far down already.
Do you guys think my setup will be okay for the season? Stock clutch and 22 top gear?
ALSO, I have a buddy that has ski-doo 8 tooth extroverts, I was wondering if that will work with my 2" track, with the tunnel protectors taken off??
Thanks, you guys have been a big help!!
Ill get some pictures once I get done.
I have run many different setup with 136 and 144 setups. I foud gearing down to help the most and then clutch to it. I am running a 144" 1-1/2 on my Attak now with 22-40 gearing. Stock clutching I think the primary is a yellow pink yellow spring. It pulls great rpms and is perfect for walking out of the deep stuff. Depends what kind of riding you are doing, Ulmer can do about anything!
- 6K
- 7K
