anyone have a valve cover gasket go bad?
yooper1
Houghton, Michigan
I have a small drip from the back of the motor coming down and I think it is a Valve cover gasket (I Hope). anyone ever had one go south? I'll pull the tank off tomorrow and look, Thanks!
Are you sure its not coming out of the air box it will come out the bottom and go on eng. if oil is over filled alittle . Check that first
X2
Thanks guys,
Here is the problem, the sled is superchagered and the air box is gone.
Plus I pulled it apart last night, it pushed the little half moon out on the back right side of the motor on the valve cover gasket. New Gasket is on its way and it will be back together Friday night. I think I may have pinched the breather line a little. I'll more it and ensure it is a non-issue going forward.
Thank you for reading and posting.
