yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I haven't had much time to troubleshoot been sledding but I got c1600 c1603 alarm (open circuit hand thumb warmers) and obviously have no hand/thumb warmers and no heated seat. I pulled steer post pad and disconnected the right hand warmer and it tested good! The other connector for the thumb warmer will not come apart !!! I am guessing it shorted in the connector and melted it together.
I need the schematic to see how everthing is wired so i can temperally take the thumb warmer out of the circuit and just run the handwarmers until I can bring to dealer
I am guessing since I lost the heated seat, hand and thumb warmers all at once that they all run on the one 25amp fuse so if one of the 3 shorts nothing works?
Dagoon
- Dec 30, 2017
- Leamington
- 2017 Yamaha Sidewinder XTX 141
Has this same issue. Check the contacts at that fuse. Mine was very loose. I could wiggle the fuse. Ended up melting the plastic around the fuse due to it arching out. Yamaha would not cover it. Take the fuse out, and bend the pins in to make a tight contact.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Ok thanks I'll Check thisHas this same issue. Check the contacts at that fuse. Mine was very loose. I could wiggle the fuse. Ended up melting the plastic around the fuse due to it arching out. Yamaha would not cover it. Take the fuse out, and bend the pins in to make a tight contact.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
My heated seat was shorted@yamamarc
Hi yamahamarc, what ended up being your problem here?
Turboflash
- Mar 18, 2019
- Southern MN
All too common issue. Shorted/broken wires at/near chip.
Bakerraker
- Feb 9, 2022
- Michigan
- 2020 SRViper LTX-GT
Near chip?All too common issue. Shorted/broken wires at/near chip.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
soo i lost my right grip last week after i saw when i took pad off center of bars that they made the wires sooo fn short that they barely connect, soo i pushe them together and then the right warmer never worked, turnes out the wires pulled out internaly from connector, so i cut them of and extended wires and crimped new ends on and every thing wrks perfect now.... they are ppulled soo tight on sterring block im surprised alot dont have issues.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
???? X2…. Near chip?All too common issue. Shorted/broken wires at/near chip.
Turboflash
- Mar 18, 2019
- Southern MN
The chip I'm referring to is on the heater pad that's underneath the seat cover. It's an electrical part that controls the electricity to the pad. Most of the time, the leads going into the chip break because the design causes those leads to flex as the rider goes up and down. Eventually they break.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
The one and only time I rode double, it was a very short ride with my wife, I found that my heated seat wouldn’t work on my next Day ride. It was taken care of by dealership through warranty, but nice to know what probably happened for next time when it’ll be me fixing it! Dealership brought my seat to a local Upholstery shop along with new seat element.The chip I'm referring to is on the heater pad that's underneath the seat cover. It's an electrical part that controls the electricity to the pad. Most of the time, the leads going into the chip break because the design causes those leads to flex as the rider goes up and down. Eventually they break.
Funny how I really like that option now whereas I wasn’t that impressed about it when it came standard on my 17 LE.
