berge75
All 4 of of the tabs snaped off,and the radiator hitting against the reverse linkage. My ziptie groomit set-up has more miles on it than the orig. and is holding up better. SAD
LJ 452
Check all the rivets that connect anything to the toe holds and radiator. I had the rad mount crack as well. Noticed it last spring and got it fixed over the summer (Yam covered it). However I did notice that all of the rivets in the toe hold support bracket were loose. May not be the main cause of failure but deffinently won't help the cause. I had a slight issue last year and the sled was on it's side (rad side) for about 10ft, there was no visible damage but I thought that was why the rad mount cracked but it looks like I'm not the only one.
mdkuni
Thanks for the heads up on this
I most likely would have never noticed this until something major happened. Sure enough, I checked last night and it is broke.
Capt.Storm
Just went out and looked at mine...outboard tab is broken.
I only noticed two tabs on top ..guess I gota look for the thrid one.
Capt.Storm
Found the bottom one broke as well.
Thanks for the heads up.
Next queston..if I take it out to have it fixed will I have to bleed the cooling system of air?
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
Dont worry about bleeding it. Fill it up, warm it up, and top off. Then after your first ride, top it off again.
