wienerwater
- Mar 1, 2007
- Northern British Columbia, Canada
Just doing some mods and wonder if anyone has installed a 174" track in their sled? I have an '03 mountain, and just trying to figure out what rails or rail mods to use. Some guys have extended the factory ones from the original , I think was a 151" track, no? Anyway, another idea presented was a newer Nytro suspension, because it's lighter (I'm told) and extending those rails, but then the rear brackets are quite different.
Any input appreciated..
northern summit
Put one on my 03 have some rail extension pm me
Rob
Rob
Frostbite
I have a 141 M7 skid out to 162 with no issues. I would think a 153" or 162" M7 skid out to 174 shouldn't be too much of an issue.
I just put a Nytro MTX skid under a 97 mountain max. It looks cool but, the nytro guys are almost giving the skids away. I have another one lined up for $100. They all seem to be upgrading the rear skid. I guess the shocks on the skid are lackluster at best.
Frosty
Frosty
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
I just put a 174 x16 x3"pitch in my 04 RX-1M about 2 weeks ago. I am using a 162" M7 skid that is set back 1" from the stock location. It fits perfectly. Only issue I have is the track sticks out past the tunnel. Last time I looked no one makes a 174" tunnel ext for the RX.
The 162" M7 skid is around 50-55#s which is about 20 #'s lighter than the stock skid.
J.
J.
Joa
Jonny, are you normally aspirated and if not how does the RX-1 pull that big track?
Jonny Rocket
Joa said:Jonny, are you normally aspirated and if not how does the RX-1 pull that big track?
I have a turbo. I have seen some naturally aspirated sleds turn the 162 pretty well and feel they would also turn the 174. Might have to gear down a little to get some track speed but it would work.
J.
wienerwater
- Mar 1, 2007
I got mine in and it fits very nice, rails extended, and it looks great!
I notice too, the track is out a little, so will have to make a little brace or bend at the flap mount to keep it bent out, but that's the only odd issue. I know of guys here running stock engines with this size track, and no problems.
