klitts
I come from the superbike world, and Rotella T6 5W40 is used quite a bit by many different riders - including R1 guys. Just wondering if anyone tried it in their Yami 4 stroke sled?
I know it's marketed for diesel, but it has all the certs for bike engines. Plus it's a lot cheaper than most other options. Don't see why I couldn't run it in my APEX.
ahicks
Yes. I run it in everything....
mckracker
I run it in my 08 Yamaha FZ6, with no problems. Never thought about running it in my Apex. I will try it out next oil change.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
klitts said:I come from the superbike world, and Rotella T6 5W40 is used quite a bit by many different riders - including R1 guys. Just wondering if anyone tried it in their Yami 4 stroke sled?
Also heard it is great oil but imo the pour point is too high to run in a sled, epecially in some of the temps I see on occassion.
klitts
DO you mean the 5w rather than 0w? I was wondering how much difference this would really make.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I am trying the Rotella T5 synthetic 0W40. I believe the sleds need 0W to be able to crank them in cold weather. I may be wrong but 5W may be a too thick when cold to crank unless you don't see extreme cold.
Something I found in another forum that makes sense:
So 0W may be better quality oil, all else being equal.
0W has factually superior cold weather cranking and pumping performance vs 5W (per the definition of the vis grade). Is it a huge difference that the average Joe would be able to detect themselves - not likely. Is it better to use a 5W vs a 0W - no. 0Ws go above and beyond the cold weather performance test requirements for 5Ws - and typically use more expensive and higher performance base oil to achieve 0W performance.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
oil
That is what I have been running in my turbo sled for the pass two years and in my super charger before that .Excellent oil...
Mooseman said:I am trying the Rotella T5 synthetic 0W40. I believe the sleds need 0W to be able to crank them in cold weather. I may be wrong but 5W may be a too thick when cold to crank unless you don't see extreme cold.
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
i run it in my FZ8 and i put it in my 09 vector LTXGT for this season. T6 being 5W doesnt bother me as i mostly do local riding and my sled is kept in the garage. cant really afford to go to the UP this year so I should be good. i see the western UP is getting some heavy wet snow . Not gettting anything here this week.
- 7K
