Clay350
- Oct 29, 2010
- Minneapolis (just moved here)
- www.treetopsmedia.com
I unplugged my annoying reverse beeper. Would that cause my temperature light to go on?
RayKnobs
- Feb 24, 2010
- Rochester, NY
- 315er.net
NO, but it will cause you to face plan when you forget it's in reverse and you punch it.
phaze5
hahaha x2 on the face plant ,
think about it happennig at the worst possible time?
your with your buddies and all of a sudden someone is taping, then all of a sudden your the subject of a virile video lmao
hearnoevil
I did that before on an old skandic, forgot I had it in revese after moving in off the trailer.
Bang face plant into the pavement. and once you hit the gas the monument will cause you to gas it more.
A Buddie of mine shut off his sled in reverse and I noticed it, I then asked him to race , he started the sled up and I went 1....2....3... and sure enough he nailed it flying backwards
BombaPolaYama
hearnoevil said:I did that before on an old skandic, forgot I had it in revese after moving in off the trailer.
A Buddie of mine shut off his sled in reverse and I noticed it, I then asked him to race , he started the sled up and I went 1....2....3... and sure enough he nailed it flying backwards![]()
Guess you mean "momentum"; because a monument would probably cause an abrupt stop. (LOL)
Phazer500
How do you unplug it?
wakattak
I unplugged mine in my attak. I had no other consequences except for being able to back up in silence. That beeper is way too loud.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
put a piece of duck tape over it..
BombaPolaYama
RIGIDONE said:put a piece of duck tape over it..
To muffle the sound? If so, where is the beeper located?
thanks,
RayKnobs
- Feb 24, 2010
- Rochester, NY
- 315er.net
It would probably be easier to find if it made some type of noise.
Ray you crack me up!
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
RayKnobs said:It would probably be easier to find if it made some type of noise.
Like an annoying beep?
yzman
You guys must be riding in reverse to get annoyed by the beeper . I don't understand how it can be such a problem ? lol
blkmax600
- Jan 4, 2009
- Lockport Manitoba
- 2007 Apex, 2007 Vector, 1988 Phazer, 1984 Bravo.
"It would probably be easier to find if it made some type of noise."
"Like an annoying beep?"
"Guess you mean "momentum"; because a monument would probably cause an abrupt stop. (LOL)"
This is exactly what I like about this site.......always full of GREAT advice!!!!! LMAO!!!!
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
its on the battery box facing the rear of the sled, its round and beeps when you put the sled in reverse. hope that helps.
