shanksRX-1
- Feb 6, 2006
- Pennellville, NY
- 2010 Apex
- Pennellville, NY
I got the anti ratchet drivers. I take it they are made by skidoo since they say bombardier on them. Do you take off all 4 of your stock drivers and replace them with just the two anti ratchet drivers??? Or do you reuse two of your stock drivers too??? Thanks!!
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Just use the 2 anti ratchet drivers
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
They have to be pressed off and the new ones pressed on as well. There is also different spacing when using extros I don't have those numbers. I was lazy and sent them to Ulmer for $40 he pressed the old off and the new on and spaced them perfect for me. Bolted it back in and away I went.
shanksRX-1
- Feb 6, 2006
- Pennellville, NY
- 2010 Apex
- Pennellville, NY
Thanks!!!
Also one more question. These drivers have 3 teeth obviously one goes through the window and one on each side to push on the track as well. But on each set of drivers on all the teeth on one side have a notch cut into them. does it matter what side the notched teeth push on the track???
shanksRX-1
- Feb 6, 2006
- Pennellville, NY
- 2010 Apex
- Pennellville, NY
kinger said:They have to be pressed off and the new ones pressed on as well. There is also different spacing when using extros I don't have those numbers. I was lazy and sent them to Ulmer for $40 he pressed the old off and the new on and spaced them perfect for me. Bolted it back in and away I went.
$40 I will do that. Whats his number and address. I would rather give him the business as the local yamaha stealer who I was gunna take it to and pay $65/hour and it will probly take them 2 hours to measure and everything.
kinger
- Jan 17, 2005
- Clear Lake, IA
www.ulmerracing.com everything is posted there. Not sure on the notches good question I will look at mine I think they are facing out but I can't remember.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
shanksRX-1 said:Thanks!!!
The notches shall be on the outside of the drivers, they are there for the track clips, like they are already worn in so you don't have to.
shanksRX-1
- Feb 6, 2006
- Pennellville, NY
- 2010 Apex
- Pennellville, NY
rxrider said:shanksRX-1 said:Thanks!!!
aaaahhhh Ic ic. That makes sense.
Well I ended up sending em to Justin @Full Power Performance. He's gunna put em on and send em back.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
