RAMSOMAIR
Just purchased a used Bender stage II kit and need install instructions. Got RX inst. but need Apex. Need instructions on how to set the Boss Noss TFI gen III controller.
powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
EFI box
I have new one that will make sled run alot better then Bender setup and clean up bottom trail riding and no need to adjust.
http://www.powderlites.com
A
Anonymous
RAMSOMAIR said:Just purchased a used Bender stage II kit and need install instructions. Got RX inst. but need Apex. Need instructions on how to set the Boss Noss TFI gen III controller.![]()
Here are instructions I got from Bender when I got it:
TO SET UP FUEL MANAGER ON APEX TURBO KITS:
START SLED – SEE LIGHTS RUN BACK AND FORTH AFTER THEY STOP SEE SINGLE LIGHT BLINK.
PRESS MODE BUTTON ONCE –
**USE (+) & (-) BUTTONS TO MOVE BLINKING LIGHT TO CORRESPONDING NUMBERS**
MOVE GREEN LIGHT TO #1 (IDLE/LIGHT THROTTLE)
MOVE YELLOW LIGHT TO #2 (MIDRANGE)
MOVE RED LIGHT TO #5 (WOT)
MOVE YELLOW/ BLUE LIGHTS TO #6 (BOOST ADD FUEL)
MOVE ORANGE/BLUE LIGHTS TO #5 (RPM MIDRANGE)
MOVE RED/BLUE LIGHT TO #2-#3(BOTH 2&3 LIGHT UP) (RPM WOT)
PRESS MODE ONCE MORE
FINISHED
But I found these settings to be too rich on low load conditions. And they are Ok only to 8 psi, if you go higher, you need to up the BOOST ADD FUEL setting.
I was to 8 on the boost add fuel at 12psi boost. (almost maximising the stock fuel pump/injectors)
I don't remember the other settings I were at last time though.
good luck!
RAMSOMAIR
Re: EFI box
Thanks mulot30th for getting down all the details! This is great info!
Regarding the powderlites, what is different/better? And how much???
Thanks!
powderlites said:I have new one that will make sled run alot better then Bender setup and clean up bottom trail riding and no need to adjust.
Thanks!
RAMSOMAIR
C'mon guys, there has got to be someone out there with Bender Apex instructions. Any help would be greatly appeciated. Just want the install to be professional and safe. Dokter C and I are working together to make this project a success.
whistlersleds
Please email to me if you get one.
If I get one I'll email it to you and the same back if you get one please.
whistlersleds@yahoo.ca
DoktorC
It looks like you have what you need...the RX instructions will get the kit installed and Mulot's has a good startup setting for the fuel box sooooo..is the seat off yet?????
Really the only issue is the fuel pump installation/location. Maybe someone has some thoughts on that.
Or maybe since you have the RX instructions....and I have and RX.........hmmm....ah well I've always said stock is best.
knock,knock,knock....BANG
A
