Yeah, I figured that but I really don't want to go looking for more parts and the Apex black probably won't match the 03 RX-1 metallic black. I thought they looked pretty close in shape and I could either trim the exhaust cover or the plastic trim but just wondered if anyone had done the same. If not I'll just use the RX-1 light and sell the Apex parts.
I've done it before and it fits perfectly. If you choose to run rx-1 taillight on apex you will have to change plug of splice wires as the seat harnesses are different.
I know that either light will fit the seat but the Apex plastic trim doesn't mate with the RX-1 exhaust covers and it looks like a small trim job might make it work. If someone has done it that would boost my confidnece, otherwise I might scrap a good piece of Apex trim by cutting it and have to go back to the RX-1 light anyway.
Click the link in my sig you can see all my pictures every step of the way.... Any questions I should be able to help you out apex covers with RX end caps fit nicely the RX plastics will also work with a slight gap which is what I ended up doing on my warrior
